Home > Technical (L322) > L322 ZF Box |
Have you tried to clean and lubricate the gear lever assembly underneath the car yet ?? They corrode a bit over time and that causes problems with the gear selection. Not sure if this is linked to it but it is a cheap way of checking. Wipe/brush clean it, liberally spray with WD40 or similar and then cover in white grease.
28th Jun 2013 11:01pm |
Hoveronly Member Since: 08 Apr 2012 Location: Salisbury Posts: 39 |
Thanks for the ideas! will have a look at the lever as suggested.
29th Jun 2013 1:39pm |
Do you know whether you have the recent software in the ECU ?? I may be worth going to a dealer or Indy that can update your software to the latest version.
29th Jun 2013 1:41pm |
Thanks again for your suggestions. Don't know about the software but will check it out! Sorry for lateness of reply but the message got stuck in my junk folder!!! |
13th Jul 2013 3:39pm |
A worn gearbox with faults can work perfectly in Command Shift mode. It was exlpained to me why but I have forgotten |
13th Jul 2013 4:29pm |
