![]() | Home > Technical (L322) > L322 ZF Box |
Have you tried to clean and lubricate the gear lever assembly underneath the car yet ?? They corrode a bit over time and that causes problems with the gear selection. Not sure if this is linked to it but it is a cheap way of checking. Wipe/brush clean it, liberally spray with WD40 or similar and then cover in white grease.
Hoveronly Member Since: 08 Apr 2012 Location: Salisbury Posts: 39 ![]() ![]() ![]() |
Thanks for the ideas! will have a look at the lever as suggested.
Do you know whether you have the recent software in the ECU ?? I may be worth going to a dealer or Indy that can update your software to the latest version.
Thanks again for your suggestions. Don't know about the software but will check it out! Sorry for lateness of reply but the message got stuck in my junk folder!!! |
A worn gearbox with faults can work perfectly in Command Shift mode. It was exlpained to me why but I have forgotten |
