Home > Maintenance & Mods (L322) > Mig welding
paneldamage
Mig welding
Hi all, I am just about to replace a small section of inner wing on my S/C using mig/ spot weld, I haven't done any car welding for years but back in the day, we used to have concerns that electric welding could damage ecu,s etc and I always unplugged the Engine Ecu - keeping in mind that in those days, that would be the only ecu on the car!
I had a look in Rave, it doesn't mention any concerns, so am I worrying for nothing?
Cheers in advance, Les
Post #197771 6th Jul 2013 8:04am
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Range rover ECU's can be very sensitive,
I would recommend disconnecting the battery, leave 10 minutes, then unplug the engine & BCEM as a minimum
Don't forget to go lock to lock on the steering when you put it all back together to reset the TC/DSC 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #197775 6th Jul 2013 8:53am
