Home > Technical (L322) > Diesel Leak
pami
United Kingdom 2008 Range Rover Vogue SE TDV8 Bournville
Diesel Leak
Afternoon Guys,
Got a slight diesel leak coming from the engine.
Appears to be from the fuel return pipe. Have any of you guys ever encountered/heard of something like that before? Only happens when its been started/driven round and then parked up. After a while the drip stops.
Not too fussed about the fuel loss as its minor but from a safety aspect, i would like it sorting!
Started taking things apart last night but decided against it as it was going to take too long.
Anyone recommend an Indie close to Wakefield/Leeds who wont robe me and be nice Crying or Very sad
Cheers Guys
Post #195170 19th Jun 2013 2:25pm
billcyn
United Kingdom 2008 Range Rover Vogue TDV8 Epsom Green
Did you find the source of this leak as I have a similar one on my 2008 TDV8.
Losing about an eggcupful every hour whilst engine is running then stops dripping
after a couple of minutes when stopped.
Post #224923 24th Nov 2013 11:38am
mike & the mechanics
United Kingdom 2007 Range Rover Vogue SE TDV8 Galway Green
Will probably be the little "O" ring that seals the leak off pipe that connects to all the injectors. I had the same on mine & bought a complete new leak off pipe from Duckworths for about £100 ish. I went down this route as its a hard plastic pipe & in my experience if one or two seals had failed then others were likely to follow. Also given the pipe that connects them all is hard plastic & after five years now probably a bit brittle thought best to change it all. Hope this helps Mike Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #224925 24th Nov 2013 11:48am
billcyn
Thanks for the reply. Is the pipe difficult to get at and replace - is this a job for a specialist dealer?
Post #224932 24th Nov 2013 2:06pm
I would prob say yes as its one piece & goes all down the passenger side then around the back & up the front of the drivers side.Rather a lot has to be stripped out the way but is well within the scope of any one who is mechanically minded. The clips that hold it on are very fiddly & if you are going to do it yourself I would get some spares as you will drop some & potentially loose them! They are only coppers & will save you hrs trying to locate them off the subframe etc.
Post #224948 24th Nov 2013 3:09pm
billcyn
Thanks for that - first thing is to see if the leak off pipe is the culprit so hope to have a go shortly.
Post #224960 24th Nov 2013 4:28pm
billcyn
Yes, the leak is from the fuel return pipe on no. 1 injector - spotted it using an inspection camera.
Going in to the garage Tuesday as removing the fuel lines cover plate is beyond me!
Post #226382 1st Dec 2013 5:35pm
Thumbs Up glad to help Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #226447 1st Dec 2013 10:45pm
pami
Hi Guys
Sorry for the late reply.
Mine was from the return pipe too. Here is a pic of the badger!
I fixed it another way..got my uncle on the case... Shocked
All sorted now!
Post #226560 2nd Dec 2013 5:20pm
billcyn
Is the pipe junction just a push fit or is it secured by spring loaded pins?
Thanks
Post #226585 2nd Dec 2013 8:08pm
pami
I think its just a push in mate
We fixed it using Thread Seal Tape (plumbers tape)
Been fine ever since and that was back in May! Plan was for it to be a temp fix until i got a new pipe but never got round to it... not leaking anymore so will do it whenever Mr. Green
Post #226649 3rd Dec 2013 9:24am
billcyn
FUEL LEAK UPDATE
Local garage finally fixed fuel leak from No:1 injector leak off pipe by replacing rubber O ring.
Charged 2 hrs labour most of which was spent removing and refitting injector pipe cover plate (7 fixing nuts),
one of which is almost inaccessible without further strip down!
Post #226934 4th Dec 2013 1:29pm
