Home > Technical (L322) > Diesel Leak |
pami Member Since: 05 Mar 2013 Location: Wakefield, West Yorkshire Posts: 52 |
Afternoon Guys,
19th Jun 2013 2:25pm |
billcyn Member Since: 20 Oct 2013 Location: Whitby Posts: 56 |
Did you find the source of this leak as I have a similar one on my 2008 TDV8.
24th Nov 2013 11:38am |
Thanks for the reply. Is the pipe difficult to get at and replace - is this a job for a specialist dealer? |
24th Nov 2013 2:06pm |
mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178 |
I would prob say yes as its one piece & goes all down the passenger side then around the back & up the front of the drivers side.Rather a lot has to be stripped out the way but is well within the scope of any one who is mechanically minded. The clips that hold it on are very fiddly & if you are going to do it yourself I would get some spares as you will drop some & potentially loose them! They are only coppers & will save you hrs trying to locate them off the subframe etc.
24th Nov 2013 3:09pm |
Thanks for that - first thing is to see if the leak off pipe is the culprit so hope to have a go shortly. |
24th Nov 2013 4:28pm |
Yes, the leak is from the fuel return pipe on no. 1 injector - spotted it using an inspection camera.
1st Dec 2013 5:35pm |
glad to help Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
1st Dec 2013 10:45pm |
Hi Guys
2nd Dec 2013 5:20pm |
Is the pipe junction just a push fit or is it secured by spring loaded pins?
2nd Dec 2013 8:08pm |
I think its just a push in mate
3rd Dec 2013 9:24am |
FUEL LEAK UPDATE
4th Dec 2013 1:29pm |
