Home > Maintenance & Mods (L322) > Alternator Gremlins
Sportex
England 2008 Range Rover Vogue TDV8 Stornoway Grey
Alternator Gremlins
Hi guys, been away for a while so apologies if this has been covered elsewhere, cant be bothered to read two years of unread topics. Had what I thought was the dreaded battery drain, and on and off over the years have had intermittent early morning flat batteries, a new battery sorted it first time, this time however it died almost immediately. I was told by recovery that the alternator was producing plenty of amps but no volts. It sounds strange to me, can it be right, anyone know of this? Is it a new alternator, which I guess is expensive and difficult to get at. No body told me there would be days like these
L Reg dark purple/burgundy sort of Disco
R Reg very red disco
Bright Silver disco TD5
Sort of bright girly powder blue disco TD5
Gone (a while back) 1999 P38 4ltre Autobiography. 13 miles to the gallon, 10,000 miles to the engine
Gone MY06 RRS HSE Rimini Red
Gone MY10 RRS HSE Purple
Gone 2007 TDV8 Vogue OF Stornoway Grey (In Love again)
2011 4.4 TDV8 Vogue Baltic Blue
MY66 VOGUE TDV6 3.0 Red
Post #191812 3rd Jun 2013 12:57pm
afaik you cant have amps without volts, you can the other way round...stick a multimeter on the battery at idle and you should get around 14.5 volts .. ... - .- -.
Post #191813 3rd Jun 2013 1:06pm
Sportex
Thanks Stan, I was not convinced, but we are all scratching our heads as to whats going on, as for months its fine, then it fails to start. Will try to get it looked at over the weekend, but any thoughts, ideas and additional info may save me getting mugged at the garage. No body told me there would be days like these
Post #191820 3rd Jun 2013 1:57pm
on top of testing the voltage output of the alternator, i would look into how long you've had the battery and also inspect the battery connections to make sure they are tight... ... - .- -.
Post #191822 3rd Jun 2013 2:01pm
Sportex
New battery, 2 days old, Varta Dynamic Silver 100 AH, nice and tight so they say! No body told me there would be days like these
Post #191824 3rd Jun 2013 2:14pm
GraemeC
Final Stage Resistor seems a common fault leading to flat batteries.... 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #191830 3rd Jun 2013 3:00pm
user58101
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
I have a Battery Brain fitted which cuts out the battery when the voltage drops below 11.7V, so the car is (almost) guaranteed to start.
Post #193347 11th Jun 2013 12:19pm
Sportex
Mine is in the garage to be stripped down at the moment for alternator investigation/replacement. Will let you know of any conclusions. No body told me there would be days like these
Post #193665 12th Jun 2013 12:50pm
