![]() | Home > Maintenance & Mods (L322) > Alternator Gremlins |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35657 ![]() ![]() |
afaik you cant have amps without volts, you can the other way round...stick a multimeter on the battery at idle and you should get around 14.5 volts .. ... - .- -.
Sportex Member Since: 12 Jun 2010 Location: Up North Posts: 366 ![]() ![]() ![]() |
Thanks Stan, I was not convinced, but we are all scratching our heads as to whats going on, as for months its fine, then it fails to start. Will try to get it looked at over the weekend, but any thoughts, ideas and additional info may save me getting mugged at the garage. No body told me there would be days like these
on top of testing the voltage output of the alternator, i would look into how long you've had the battery and also inspect the battery connections to make sure they are tight... ... - .- -.
New battery, 2 days old, Varta Dynamic Silver 100 AH, nice and tight so they say! No body told me there would be days like these
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
Final Stage Resistor seems a common fault leading to flat batteries.... 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car! |
user58101 Member Since: 13 May 2012 Location: London Posts: 11 ![]() ![]() ![]() |
I have a Battery Brain fitted which cuts out the battery when the voltage drops below 11.7V, so the car is (almost) guaranteed to start. |
Mine is in the garage to be stripped down at the moment for alternator investigation/replacement. Will let you know of any conclusions. No body told me there would be days like these
