![]() | Home > In Car Electronics (L322) > Venture Cam Repair. |
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 ![]() ![]() ![]() |
VMPP, have you left it charging for long enough? You may need to keep it in the charger during a long journey.
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 410 ![]() ![]() ![]() |
Yes, it has now been on the car for some time.
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
^ I would open it up again and double check the wiring... Just in case.. Previously..
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3866 ![]() ![]() ![]() |
Just done this camera now works |
TerryT-J Member Since: 02 Sep 2013 Location: Johnston, Pembrokeshire Posts: 86 ![]() ![]() ![]() |
Iv'e just done this as well but as others say watch out for that single clip. I split mine but managed to weld it back together with the soldering iron. I got my rechargable batteries from Maplins. Their own brand, 1000mah and 12.99 for a pack of 12 so you can make up a second pack ready for when your first one fails!!!! |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 793 ![]() ![]() ![]() |
My camera shuts down just after a second or two of image and then I only get static on the screen; however the orange leds stay on forever (well, for a very long time anyway, I left it on for at least an hour)… Does this still mean the batteries are the problem? Or should the leds die too? Thank you for confirming this! |
No after the batteries are too gubbed to operate the camera they will still work the LED's for quite a while. 2008 MY Supercharged
Thank you, seems like I’ll have to start the battery replacement procedure… |
Well I managed to replace the batteries, it took one hour and of course I broke the bottom tab while opening the case, so I thought maybe a picture of the cover would help future brave Venturecam owners in locating those tabs. I replaced the batteries with 6 Varta NiMH 800mAh and now it is working great! I must say though, the old batteries are still delivering 7.6V (but only 0.6A)...
This is weird, the camera is working, it can be viewed on the screen when its button is pressed, but it cannot be activated from the screen’s menu. And it is not charging. I got 12v at the cradle’s connector, I re-checked the wires in the cam, but it doesn’t charge when inserted, there is no progress bar and no green charging light. I am starting to believe this is the cause for the old batteries’ malfunction. What am I doing wrong? |
max Member Since: 28 May 2014 Location: milano Posts: 30 ![]() ![]() ![]() |
thanks 999, this is mine, tested on the car today : perfect !
SO3isme Member Since: 18 May 2014 Location: Woking Posts: 110 ![]() ![]() ![]() |
Does anyone think this item may be worth pursuing?
crispy2 Member Since: 18 Aug 2013 Location: Mandurah Posts: 102 ![]() ![]() ![]() |
Thanks Dave699, I had the same problem with no activity frm my Venturecam from my recently acquired 2007 S/C. Had a read of this, down to the supermarket for the same batteries, a bit of soldering last night, now in business. all lights working as they should, now just got to bond the two halves together then make sure it's all paired up and put to use.
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Ive just done ours, we had 3 out of 6 dead cells in the AAA's.
