Home > Maintenance & Mods (L322) > Replacement reverse camera
Tayas
My camera is kaput so needs replacing. I've done a search and read all the threads I can find on camera replacement but I couldn't find any info about what to replace it with. Obviously, I'm not going to drop the crazy money LR want for a new one so what's the way forward?
Taking it apart, it has a square connector with 4 pins. 2 are composite I guess and the other 2 are power and ground. Surely any old reversing camera from ebay will work and can be fitted inside the housing. Any recommendations? 2006 FFRR 4.2 Supercharged Vogue SE
2007 Honda S2000
2008 Aprilia Tuono Factory
Post #188636 16th May 2013 10:14am
this might help,
http://www.fullfatrr.com/forum/search.php?...rch_time=0 ... - .- -.
Post #188639 16th May 2013 10:27am
Tayas
Re: Replacement reverse camera
I've not found anything specific on what to replace it with other than the newer module from a 2010 model.
I would like to know if anyone has replaced the guts of the original camera module with a different camera and what did they use. 2006 FFRR 4.2 Supercharged Vogue SE
2007 Honda S2000
Post #188643 16th May 2013 10:48am
supershuttle
I bought this and it seems to work fine with my 2007 touch screen.
Just cables to cut and join
E-Bay item number eBay Item No. 261050835380 Geoff
Post #188702 16th May 2013 3:37pm
Tayas
Great, thanks. I'll bag one of those and see. 2006 FFRR 4.2 Supercharged Vogue SE
2007 Honda S2000
Post #188715 16th May 2013 4:46pm
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
Where did you mount this and do you have any pics of the install and result? Thanks African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #189526 20th May 2013 10:42pm
supershuttle
Isn't it odd that as soon as you stick a finger in the flash goes off Shocked
I suppose you want pictures now of the screen, well if so you'll have to wait Very Happy Geoff
Post #189549 21st May 2013 7:21am
Cheap as chips that!
Post #189552 21st May 2013 7:27am
DeRanged Rover
That looks very tidy!
Did you just get rid of the housing for the oem camera and was it just a case of splicing the wires together? If so I may give this a try! African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
Post #189588 21st May 2013 10:52am
here's a thought, why not have 2/3 or 4 cameras and use a video splitter or cctv splitter to see all these on the screen.. ... - .- -.
Post #189589 21st May 2013 10:55am
Tayas
Could easily be achieved. You could have one on the front and one each side looking down then have 4 images on the one screen using something like this: http://www.ebay.co.uk/itm/4-Channel-CCTV-C...4d096226cf 2006 FFRR 4.2 Supercharged Vogue SE
2007 Honda S2000
Post #189622 21st May 2013 2:06pm
that's similar to the cctv unit i have and indeed it would be cool to have 4 images from 4 different cameras on the screen when you reverse..
my cctv unit also does 2 images side by side which would fill the screen a bit better.. ... - .- -.
Post #189625 21st May 2013 2:59pm
Tayas
I think this will have to be investigated. I shall buy one of those units and some more cameras once I'm back from Poland. 2006 FFRR 4.2 Supercharged Vogue SE
2007 Honda S2000
Post #189628 21st May 2013 3:15pm
supershuttle
The original camera was missing from this spoiler ( I bought it secondhand) my original camera was slightly damaged Whistle But they do come off easy enough, just drill out the rivets, the new one is just stuck on with double sided tape and as Gary says the whole thing is cheap as chips and better than the original camera Thumbs Up
Stan has me thinking multiple cameras now maybe with a selector switch Question Geoff
Post #189630 21st May 2013 3:39pm
RR2008HSE
I'd love to get details, once you have the multi camera setup. Maybe we could get the whole 'Adventure Cam" setup on pre2010 cars! Very Happy
Post #189719 22nd May 2013 2:39am
