Home > Maintenance & Mods (L322) > Replacement reverse camera
re the multi camera setup, this might be of interest,
http://www.ebay.co.uk/itm/SD-Car-DVR-Digit...3a8160f0c4 ... - .- -.
Post #189794 22nd May 2013 10:31am
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
supershuttle wrote:
I bought this and it seems to work fine with my 2007 touch screen.
Just cables to cut and join
E-Bay item number eBay Item No. 261050835380
Sorry to have to resurrect this but I got the same camera as you Supershuttle but struggling with the install ... when you say "cables to cut and join" whereabouts did you make the cut? I am about to try this on the weekend (my local garage guy refused to meddle with the wiring as it was an aftermarket camera) and don't want to mess anything else up.
Presumably the cut needs to be in a watertight region so that there is no risk of water ingress ... and did you solder the cables together or just splice and use insulating tape?
Many thanks!
C African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #235493 17th Jan 2014 11:23am
bazwd
United Kingdom 2006 Range Rover Vogue Td6 Java Black
I bought one of these and eventually got around to installing it this weekend BUT, although the picture is clear, the image is flipped horizontally (not mirrored) so a vehicle parked at the rear offside is showing on the camera image as being on the rear nearside.
Any ideas on how to correct this, please?
Many thanks
Post #257623 4th May 2014 4:27pm
