Home > Technical (L322) > '07 Sidelight Lens Melting
Just noticed this on my new '07 S/C. Top of the lens looks like it's melted. Both sides are the same.
Luckily, there was another '07 (TDV8) parked nearby. It's got a tiny bit of this but not as much.
Anyone able to tell me what's going on? Nothing is malfunctioning here so it appears caused by excessive heat.
I assume a proper fix is the entire replacement of the lights?
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Si. <This is my name.
Post #188427 15th May 2013 11:46am
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
I Suspect it is heat from the cornering bulb (Extra lamp that cones on when you have nmore than 70 degrees of lock on) that has caused the damage.
I am sure I read somewhere that after about 30 seconds they can generate enough heat to start melting the lamp casing. 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #188435 15th May 2013 12:11pm
Its the adaptive/cornering bulbs heating it up too much. Are they the right spec?
I'd be tempted to put in a warranty claim if possible and then when replaced switch to LED's to stop it happening again.
Dont forget there isnt much space around them for heat to dissipate and at some of the temps we have seen over the last few years they will have gone from -10 to +20'c very quickly at times and in that confined area... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #188437 15th May 2013 12:17pm
there are 2 wattages for h7/h8 bulbs, 35w and 55w ..not sure which type is in those headlights but you might have the higher incorrect wattage in.. ... - .- -.
Post #188439 15th May 2013 12:25pm
Thanks gents. Thumbs Up
The S/C's popping back to the dealer soon for a few things to be sorted and I'll add this to the list. Si. <This is my name.
Post #188442 15th May 2013 12:31pm
ebajema
I suggest to switch to LED bulbs for that one. MY 2010 5.0 SC Galway green and sand interior!!
Post #188457 15th May 2013 1:37pm
Yes, agreed. Thumbs Up But I have to get the lenses corrected first if I'm being completely pedantic about this.
Are the LED's a straight swap or do they require a wiring modification to work properly? Si. <This is my name.
Post #188461 15th May 2013 1:50pm
if you get canbus error free leds it'll be a straight swop.. ... - .- -.
Post #188463 15th May 2013 1:58pm
Ta! Thumbs Up Bow down Si. <This is my name.
Post #188465 15th May 2013 2:07pm
PS if you can keep the old lamps let me know as i have a use for them Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #188466 15th May 2013 2:24pm
ebajema
Are you in for a new desk Will Wink Wink Wink Wink
I totally agree you would need new headlights, this is ridiculous, I wouldn't want that either.
Ask Craig if he has some lying around from his 2010 facelift jobs if the garage starts being "difficult" Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #188468 15th May 2013 2:58pm
ha ha, i could just see some of my colleagues faces if i tried that as well as the 'well at least that one works at least' type stuff!!
Was thinking more of having a semi decent set for off road jollies as i refuse to pay fleabay prices for them and they are simples to swap out and take about 15mins all in including the grille Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #188470 15th May 2013 3:13pm
pld118
Well, the main dealer response to this will be interesting (has sir left full lock on whilst cleaning/ maintaining.. swapped the bulbs etc).
Fingers crossed...
Post #188506 15th May 2013 6:43pm
Yes be interesting as new lamps is a big expense....
Post #188508 15th May 2013 6:45pm
That thought had occurred to me.
Luckily, I have pictures of mine on the day of the test drive and you can clearly see the same defect when zooming in on the picture. Thumbs Up Si. <This is my name.
Post #188509 15th May 2013 6:47pm
