Home > Technical (L322) > '07 Sidelight Lens Melting |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
Just noticed this on my new '07 S/C. Top of the lens looks like it's melted. Both sides are the same.
15th May 2013 12:46pm |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
I Suspect it is heat from the cornering bulb (Extra lamp that cones on when you have nmore than 70 degrees of lock on) that has caused the damage.
15th May 2013 1:11pm |
Its the adaptive/cornering bulbs heating it up too much. Are they the right spec?
15th May 2013 1:17pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35193 |
there are 2 wattages for h7/h8 bulbs, 35w and 55w ..not sure which type is in those headlights but you might have the higher incorrect wattage in.. ... - .- -.
15th May 2013 1:25pm |
Thanks gents.
15th May 2013 1:31pm |
Yes, agreed. But I have to get the lenses corrected first if I'm being completely pedantic about this.
15th May 2013 2:50pm |
if you get canbus error free leds it'll be a straight swop.. ... - .- -.
15th May 2013 2:58pm |
Ta! Si. <This is my name.
15th May 2013 3:07pm |
PS if you can keep the old lamps let me know as i have a use for them FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
15th May 2013 3:24pm |
Are you in for a new desk Will
15th May 2013 3:58pm |
ha ha, i could just see some of my colleagues faces if i tried that as well as the 'well at least that one works at least' type stuff!!
15th May 2013 4:13pm |
Well, the main dealer response to this will be interesting (has sir left full lock on whilst cleaning/ maintaining.. swapped the bulbs etc).
15th May 2013 7:43pm |
Yes be interesting as new lamps is a big expense.... |
15th May 2013 7:45pm |
That thought had occurred to me.
15th May 2013 7:47pm |
