Home > Technical (L322) > Rear tailgate
Chinese
England 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
Rear tailgate
Anybody any idea why my rear tailgate won't open when I push the button??
Post #186667 5th May 2013 1:04pm
Upper or lower section? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #186669 5th May 2013 1:22pm
Chinese
Sorry the lower section
Post #186671 5th May 2013 1:24pm
You need to find out if the switch is the fault or the cabling inside or the activation signal from the bcm as the switch sends a signal to the bcm which then triggers a relay which fires the motors.. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #186673 5th May 2013 1:25pm
Chinese
Tried the switch and its not that so bit more investigation needed!! Thanks
Post #186675 5th May 2013 1:31pm
Fuse 16 rear fuseboard or the relay located just above the rear fuseboard.
Item 3, you could just byepass the relay and the locks should work.
Post #186685 5th May 2013 2:43pm
PS relay 3 is interchangeable with the one below it that is resting at a horizontal position Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #186698 5th May 2013 4:14pm
