Home > Technical (L322) > Rear tailgate |
Chinese Member Since: 23 Apr 2013 Location: Oxford Posts: 9 |
Anybody any idea why my rear tailgate won't open when I push the button?? |
5th May 2013 1:04pm |
Upper or lower section? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
5th May 2013 1:22pm |
Sorry the lower section |
5th May 2013 1:24pm |
You need to find out if the switch is the fault or the cabling inside or the activation signal from the bcm as the switch sends a signal to the bcm which then triggers a relay which fires the motors.. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
5th May 2013 1:25pm |
Tried the switch and its not that so bit more investigation needed!! Thanks |
5th May 2013 1:31pm |
PS relay 3 is interchangeable with the one below it that is resting at a horizontal position FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
5th May 2013 4:14pm |
