Home > In Car Electronics (L322) > DVD Changer Operation Question
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
My DVD changer has never worked, comes up 'Mecha Error' when you try to play a disc
My question is this - maybe someone could confirm .... When you put a loaded cartridge in should it pull each drawer out to check what trays are loaded? mine doesnt, it just sits there .... Presumably it should do this.
Post #184423 24th Apr 2013 11:35am
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Yes, mine goes through all the CD's before starting to play the 1st.
Post #184514 24th Apr 2013 7:07pm
Katash
Hmmm OK thanks, guess I'm gonna have to pull mine out and dismantle it
When I put the cartridge in mine the right hand section lowers but doesn't seem to go all the way down to be level with tray 1, maybe something is jammed inside or a worm gear is stuck.
Post #184518 24th Apr 2013 7:27pm
GTJones
Wales 2002 Range Rover Vogue Td6 Epsom Green
Before you strip it out just give the cartridge a tap with the handle of a screwdriver, this will sometimes dislodge the drive mechanism and it should start to work.
Worth a try before you try and remove it as you have to drop the whole glove box to access the three retaining screws and it is a pain.
When i took mine out i have replaced it without the screws so if it sticks again it is easy to remove.
Gary Idea
Post #184569 24th Apr 2013 10:36pm
Katash
Talking about the DVD changer here not the CD changer, did try the tap trick on it tho.
Post #184574 24th Apr 2013 11:10pm
