Home > Technical (L322) > Heater always too hot
jonlewis
2007 Range Rover Vogue TDV8 Buckingham Blue
Any ideas ?
The in-car temp is always quite a bit higher than the indication on the dials. For example 18 degrees on the dial equates to 22.4 degrees on a thermometer. Only if I dial it all the way down to 16 do I really get much cold air coming into the cabin.
The aircon works fine... same thermometer says 4.4 degrees at the vent if on full blast.
In other words "Auto" seems to be mis-reading the temperature to my eyes. 2011 Stornaway Grey 5.0SC Autobiography
Post #182583 12th Apr 2013 5:44pm
Dirty in car temperature sensor?
Post #182589 12th Apr 2013 7:07pm
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
Are you using the 'air blend' roller switch?
The horizontal dial marked Blue / Red.
On mine this significantly alters the temperature of the air from the vents.
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #182593 12th Apr 2013 7:21pm
bozmandb9
Will this not be the notorious final stage resistor which always goes wrong? Range Rover-less at the moment - Pining!
Post #182594 12th Apr 2013 7:24pm
daveo
this is the temp sensor that was mentioned in the previous post
it does get very dirty and it sit in front of a fan
if the fan is glogged up and not turning,as my one was... it will not pass the cabin air accross the sensor to give an accurate temperature.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  V8 facelift Range Rover Autobiography 22" wheels.
Post #182617 12th Apr 2013 8:32pm
jonlewis
Thanks for the ideas... I assume the cabin air sensor is the one in the central dash pillar.
It looks clean from the outside, but of course that means nothing at all... will have a look at how to remove and clean properly.
The fans work well so I doubt it is FSR, but again worth a look.
The airblend is on full cold as an attempt to counteract, but still the car can be like a sauna. 2011 Stornaway Grey 5.0SC Autobiography
Post #182635 12th Apr 2013 9:37pm
jon, does the temperature read correctly when in manual mode, if it does then concentrate on the temp sensor.. ... - .- -.
Post #182657 13th Apr 2013 6:54am
jonlewis
Not sure how to read it in manual mode. All the vents come out a different temperature, but of course if you read the overall temp it rises above the setting as warm air never stops being pushed in.
Did do a more scientific test on the Auto mode and it seems I get the following readings
Setting (Reading)
18 (20.7)
20 (23.4)
22 (26.2)
24 (28.5)
So it does look like a faulty temp sensor. 2011 Stornaway Grey 5.0SC Autobiography
Post #182686 13th Apr 2013 9:45am
jonlewis
Forgot to ask.... I assume that removing it to clean is actually a major dismantling job ? 2011 Stornaway Grey 5.0SC Autobiography
Post #182687 13th Apr 2013 9:47am
Yes how do we get at the sensor?
Post #182691 13th Apr 2013 9:54am
ebajema
I guess a big ass compressor blowing into the sensor area is not the best thing to do ???? Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #182695 13th Apr 2013 10:15am
If you follow this video and work down to the grille intake panel it should be self explanatory.
Post #182705 13th Apr 2013 11:23am
jonlewis
Got the unit out but did not have time to do the full job of removing the back panel to reveal the circuit board. Used a hoover on the back of the unit to clear out the fan though and can see it is spinning freely.
If not done the trick I will remove with more time tomorrow and do the proper job.
Thanks for all the help. 2011 Stornaway Grey 5.0SC Autobiography
Post #182767 13th Apr 2013 3:24pm
OK I have the Unit Out how to I get inside to clean Temp sensor? Embarassed
Post #198002 8th Jul 2013 12:52pm
