Home > Technical (L322) > Heater always too hot |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Dirty in car temperature sensor? |
12th Apr 2013 7:07pm |
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 |
Are you using the 'air blend' roller switch?
12th Apr 2013 7:21pm |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
Will this not be the notorious final stage resistor which always goes wrong? Range Rover-less at the moment - Pining! |
12th Apr 2013 7:24pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
this is the temp sensor that was mentioned in the previous post
12th Apr 2013 8:32pm |
jonlewis Member Since: 06 Nov 2012 Location: UK Posts: 308 |
Thanks for the ideas... I assume the cabin air sensor is the one in the central dash pillar.
12th Apr 2013 9:37pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35368 |
jon, does the temperature read correctly when in manual mode, if it does then concentrate on the temp sensor.. ... - .- -.
13th Apr 2013 6:54am |
Not sure how to read it in manual mode. All the vents come out a different temperature, but of course if you read the overall temp it rises above the setting as warm air never stops being pushed in.
13th Apr 2013 9:45am |
Forgot to ask.... I assume that removing it to clean is actually a major dismantling job ? 2011 Stornaway Grey 5.0SC Autobiography |
13th Apr 2013 9:47am |
Yes how do we get at the sensor? |
13th Apr 2013 9:54am |
I guess a big ass compressor blowing into the sensor area is not the best thing to do ???? MY 2010 5.0 SC Galway green and sand interior!!
13th Apr 2013 10:15am |
If you follow this video and work down to the grille intake panel it should be self explanatory.
13th Apr 2013 11:23am |
Got the unit out but did not have time to do the full job of removing the back panel to reveal the circuit board. Used a hoover on the back of the unit to clear out the fan though and can see it is spinning freely.
13th Apr 2013 3:24pm |
OK I have the Unit Out how to I get inside to clean Temp sensor? |
8th Jul 2013 12:52pm |
