Home > General > Do you have this? |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 779 |
This rubber seal is only present on the rear left arch on my car. Can anyone check if/where do you have it? What’s it for? Thank you!
5th Mar 2010 3:11pm |
It's to stop the paint being removed when mud/grit/water is flicked up at 70mph. No mine doesnt have it, I also have no paint left and a serious rust problem in both wheel arches |
5th Mar 2010 3:42pm |
It looks like a common profile, I guess it could be added, do you think it should be only on the rear arches or on all 4 of them?
5th Mar 2010 5:48pm |
I checked on 2 Range Rovers and the joint is present only on the rear left arch on all of them. I tried to put the joint on my right wheel arch and it doesn't fit, there isn't enough space. |
9th Mar 2010 4:01pm |
jayzee Member Since: 14 Oct 2009 Location: UK Posts: 342 |
Thought the wings were alley? Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD! |
10th Mar 2010 12:33am |
I can confirm that on the right arch, the one that doesn't have a seal, the paint has faded and the white layer is visible. |
10th Mar 2010 6:14am |
