Home > General > Do you have this?
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Do you have this?
This rubber seal is only present on the rear left arch on my car. Can anyone check if/where do you have it? What’s it for? Thank you!
Post #14354 5th Mar 2010 3:11pm
dan_uk_1984
It's to stop the paint being removed when mud/grit/water is flicked up at 70mph. No mine doesnt have it, I also have no paint left and a serious rust problem in both wheel arches Sad
Post #14359 5th Mar 2010 3:42pm
adara
It looks like a common profile, I guess it could be added, do you think it should be only on the rear arches or on all 4 of them?
Post #14367 5th Mar 2010 5:48pm
adara
I checked on 2 Range Rovers and the joint is present only on the rear left arch on all of them. I tried to put the joint on my right wheel arch and it doesn't fit, there isn't enough space.
Post #14586 9th Mar 2010 4:01pm
Macdaddy
2003 Range Rover Autobiography 4.4 V8 Java Black
I dont have it....... Hence the paints removed itself on one wing !!
Good job its booked in for it sorting or it'll start to rust Crying or Very sad TDV8 HST Sport **Current**
4.4 V8 Autobiography and 22" wheels **Gone**
Post #14610 9th Mar 2010 6:38pm
jayzee
2006 Range Rover Vogue SE Supercharged Java Black
Thought the wings were alley? Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD!
Post #14651 10th Mar 2010 12:33am
adara
I can confirm that on the right arch, the one that doesn't have a seal, the paint has faded and the white layer is visible.
Post #14652 10th Mar 2010 6:14am
