Home > Technical (L322) > TDV8 Injector Numbering |
Ronnie are you using a diag machine to see the live values of the injector and know its leaking or blocked?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
26th Mar 2013 7:00pm |
Ronnie Member Since: 26 Mar 2013 Location: Essex Posts: 2 |
Yes, my son has a SO one and has picked up a fault on injector 3 (low pressure).
27th Mar 2013 7:33am |
I think that will be the quickest as long as you can clear the fault codes although pulling it off shouldn't make it idle any worse as I bet its like mine and lumpy enough to shake the engine FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
27th Mar 2013 7:39am |
It won't be fast enough for todays job, but try this next time you need any info.
27th Mar 2013 7:55am |
