Home > Wheels & Tyres > TPMS - replacing the battery?
GraemeC
Unlike most, my TPMS works fine!
Replacing my tyres soon - is there a battery in the 'wheel' part of the system? If so, what type?
Thanks 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #178845 21st Mar 2013 10:58am
ebajema
From what I understand there is indeed a battery in the sensor in the wheel that lasts about 8 years. No idea on type and how to replace it but a good look on Ebay may help Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #178847 21st Mar 2013 10:59am
if its not broken dont try and fix it... Thumbs Up ... - .- -.
Post #178855 21st Mar 2013 11:13am
GraemeC
But its a Range Rover - 5 miles after replacing my tyres the batteries in the sensors are bound to run out.... Mr. Green 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #178857 21st Mar 2013 11:15am
ok, you win.. Laughing ... - .- -.
Post #178859 21st Mar 2013 11:23am
taskam
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Decided to have a look. After some digging found that it's a coin cell, CR2450S, soldered to the board as you would expect.
So could be replaced, but would need to be re-encapsulated. Probably not worth the time since you can get 4 for about 30 quid on ebay. 2007 TDV8 Vogue SE Java Black
Post #179058 22nd Mar 2013 9:55am
ebajema
Thanks Taskam, good write-up. I wish I got that lot that was on ebay the other day, just for next time when my tires need changing (should be a while though). MY 2010 5.0 SC Galway green and sand interior!!
Post #179061 22nd Mar 2013 10:05am
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
is there a way of testing to see how much life is in the battery?
just wondering if that could forecast lifespan
Post #179078 22nd Mar 2013 12:51pm
taskam
The potting compound is reasonably soft, so you could probe down onto the two pads that the battery is soldered to and measure the voltage that way.
Next question: any way these lithium cells can be recharged without exploding? Anywhere I've looked says not. 2007 TDV8 Vogue SE Java Black
Post #179086 22nd Mar 2013 1:38pm
i'd google that one..
but, is this not a lot of hassle if the new valves can be brought for £30'ish.. ... - .- -.
Post #179090 22nd Mar 2013 1:44pm
taskam
Agreed, provided that they self program, it makes sense to replace. The valve stems get corroded after a few years anyway. 2007 TDV8 Vogue SE Java Black
Post #179104 22nd Mar 2013 3:16pm
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
Mine reprogrammed themselves within about 7-8 miles.
4 brand new sensors. If your spare is monitored and you replace that sensor, I believe it has to go on as a road wheel to register it, before putting it back in the boot.
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #179119 22nd Mar 2013 4:28pm
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Having just done this....
Sensors are only good for 7 years.
Sealed units, you can replace valve stem apparently , but not Battery
The bloke on eBay sells set of 4 brand new at £31 buy it now, whatever you do, insist that he
Sends you the nuts!!! I had to nag him for a fortnight. Nuts are made of soft metal . Very hard to reuse existing ones.
You need the UK ones on 433 MHz frequency Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #179124 22nd Mar 2013 5:01pm
GraemeC
Thank you E 4 Guy Thumbs Up
My sensors arrived yesterday and were missing the nuts - I was thinking I'd reuse the old ones until I saw your post!
I have contacted the seller through ebay (probably the same chap as you!) and asked him to send me a set of nuts.
I've told him I need them for next Sat as I'm booked in for new tyres then, they had better get to me in time Evil or Very Mad
(I was going to try and get them done this weekend but they cant get the tyres until Monday) 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #182524 12th Apr 2013 10:40am
