Home > Wheels & Tyres > TPMS - replacing the battery? |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
Unlike most, my TPMS works fine!
21st Mar 2013 10:58am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35430 |
if its not broken dont try and fix it... ... - .- -.
21st Mar 2013 11:13am |
21st Mar 2013 11:15am |
ok, you win.. ... - .- -.
21st Mar 2013 11:23am |
taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121 |
Decided to have a look. After some digging found that it's a coin cell, CR2450S, soldered to the board as you would expect.
22nd Mar 2013 9:55am |
Thanks Taskam, good write-up. I wish I got that lot that was on ebay the other day, just for next time when my tires need changing (should be a while though). MY 2010 5.0 SC Galway green and sand interior!!
22nd Mar 2013 10:05am |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 |
is there a way of testing to see how much life is in the battery?
22nd Mar 2013 12:51pm |
The potting compound is reasonably soft, so you could probe down onto the two pads that the battery is soldered to and measure the voltage that way.
22nd Mar 2013 1:38pm |
i'd google that one.. but, is this not a lot of hassle if the new valves can be brought for £30'ish.. ... - .- -. Y. O. L. O. . |
22nd Mar 2013 1:44pm |
Agreed, provided that they self program, it makes sense to replace. The valve stems get corroded after a few years anyway. 2007 TDV8 Vogue SE Java Black |
22nd Mar 2013 3:16pm |
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 |
Mine reprogrammed themselves within about 7-8 miles.
22nd Mar 2013 4:28pm |
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 |
Having just done this....
22nd Mar 2013 5:01pm |
Thank you E 4 Guy
12th Apr 2013 10:40am |
