Home > Maintenance & Mods (L322) > Heated seat pad
Page 3 of 3 <123
Deasy
United Kingdom 2002 Range Rover Vogue 4.4 V8 Java Black
Well you have
2 for the base element,
1 for the squab element
Then all the rest are connections for motors etc
Il take a pic of the spare that I have so you know which connector to look for
Post #186690 5th May 2013 3:25pm
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
Deasy thanks. 2009 Vogue TDV8 Nara Bronze
2002 Vogue V8 Zambezi Silver
1986 90 Pick up Deep Bronze Green
1978 Series III SWB Deep Bronze Green
Post #186727 5th May 2013 6:53pm
Deasy
The underside of the seat pad
These two connectors go to each rear corner of the seat trim, they are for the elements
And it was the connector that was the culprit
Post #186731 5th May 2013 7:04pm
Rich86
Deasy, thanks.
When I get round to doing this job I will use these photos as a guide. 2009 Vogue TDV8 Nara Bronze
Post #186733 5th May 2013 7:07pm
Deasy
No problem. Hope it helps and I hope you have the same easy fix as me Smile Thumbs Up
Post #186736 5th May 2013 7:10pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Great info, thank you! My driver’s seat is not heating, I have the 5 seconds led’s on and then nothing, so I found the connectors (the ones with the yellow arrows in the picture) and measured them on both seats. The multimeter shows continuity, so does this mean that the seat rest heater could be defective?
Post #186788 6th May 2013 9:40am
Deasy
Possibly, my broken connector was the car loom side not the heat pad side of the connector
Maybe press the button and see if you get 12v??
To check the squab is easy, the leather back bit has 3 elastic straps that connect onto the bottom of the seat, then a small screw either side at the back, the it lifts up an off.
That will expose the connectors in the back of the seat.
What continuity reading did you get? As a heater element it shouldn't be a dead short. Maybe 20ohms or something like that? A dead short is just as bad as an open circuit
Post #186794 6th May 2013 10:19am
adara
This is weird, I get 0.5 ohms on all the elements, including the ones from the passenger seat, where the heater is working...
Post #186807 6th May 2013 11:15am
Deasy
Aslong as there all the same then that proves you element is fine.
So might be relay, or the back element. Or the fuse?
Have you checked your getting 12v to the connector?
Post #186808 6th May 2013 11:44am
adara
Thank you for the tips! I wil check all this in the morning...
Post #186857 6th May 2013 5:49pm
adara
OK, so I dismantled the rear seat back on both seats. There is only one heater connector and it is reversed compared to the seating pad, anyway, on the passenger seat there is continuity, but not on the driver seat… I presume the back heating element is even harder to find and replace than the one from the seating pad…
Post #187096 7th May 2013 6:21pm
adara
After a very long time I managed to finally find the problem of my driver seat heating element, it was the connection between the backrest heater and the cable that goes to the connector… The cable is attached to the resistor through a small disk that was probably riveted but now is completely rusted… It is really hard to get to this connection point as it’s sewn into the seat cover. But after twisting the cable around the resistor end and soldering them together it’s working at last!
Post #289199 27th Oct 2014 3:02pm
adara
The circled area is the connection point where corrosion was present.
Post #289202 27th Oct 2014 3:12pm
kyle h.
United States 2006 Range Rover Westminster 4.2 SC V8 Java Black
thanks to the motivation of this thread, i just got done fixing the back seat element wiring connection. My gray wire was disconnected in the cushion. I was able to do it all w/o removing the seat. You'll have to get creative pulling the lower portion of the back leather cover loose and pull it through the front of the seat to access the connection point.
Post #408341 8th Oct 2016 7:01pm
Page 3 of 3 <123
