Home > Maintenance & Mods (L322) > Heated seat pad |
Deasy Member Since: 26 Oct 2011 Location: Warwickshire Posts: 210 |
Well you have
5th May 2013 3:25pm |
The underside of the seat pad
5th May 2013 7:04pm |
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 |
Deasy, thanks.
5th May 2013 7:07pm |
No problem. Hope it helps and I hope you have the same easy fix as me |
5th May 2013 7:10pm |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 783 |
Great info, thank you! My driver’s seat is not heating, I have the 5 seconds led’s on and then nothing, so I found the connectors (the ones with the yellow arrows in the picture) and measured them on both seats. The multimeter shows continuity, so does this mean that the seat rest heater could be defective?
6th May 2013 9:40am |
Possibly, my broken connector was the car loom side not the heat pad side of the connector
6th May 2013 10:19am |
This is weird, I get 0.5 ohms on all the elements, including the ones from the passenger seat, where the heater is working... |
6th May 2013 11:15am |
Aslong as there all the same then that proves you element is fine.
6th May 2013 11:44am |
Thank you for the tips! I wil check all this in the morning... |
6th May 2013 5:49pm |
OK, so I dismantled the rear seat back on both seats. There is only one heater connector and it is reversed compared to the seating pad, anyway, on the passenger seat there is continuity, but not on the driver seat… I presume the back heating element is even harder to find and replace than the one from the seating pad…
7th May 2013 6:21pm |
After a very long time I managed to finally find the problem of my driver seat heating element, it was the connection between the backrest heater and the cable that goes to the connector… The cable is attached to the resistor through a small disk that was probably riveted but now is completely rusted… It is really hard to get to this connection point as it’s sewn into the seat cover. But after twisting the cable around the resistor end and soldering them together it’s working at last! |
27th Oct 2014 3:02pm |
The circled area is the connection point where corrosion was present.
27th Oct 2014 3:12pm |
kyle h. Member Since: 15 Feb 2016 Location: West Virginia Posts: 23 |
thanks to the motivation of this thread, i just got done fixing the back seat element wiring connection. My gray wire was disconnected in the cushion. I was able to do it all w/o removing the seat. You'll have to get creative pulling the lower portion of the back leather cover loose and pull it through the front of the seat to access the connection point. |
8th Oct 2016 7:01pm |
