Home > Maintenance & Mods (L322) > Remapping MY10 3.6 TDV8 vogue SE
martin g
2010 Range Rover SE TDV8 Santorini Black
I had all my sport tdv6's remapped and the difference was really noticable. I have now upgraded to a 3.6 TDV8 vogue SE and I am thinking of having this one remapped as well. Are the claimed figures correct 4 to 6 mpg gain, 90nm more torque and an extra 50 bhp. Has any one had their 3.6 remapped and was the difference noticable. Any feedback will be most welcome.
Post #177921 16th Mar 2013 4:08pm
I use the Superchips bluefin module on mine.
Makes a big difference to low end grunt, but can't say I've seen a lot of difference on the MPG.
A lof of people speak highly of JE Engineering, but I'm a bit too far away for them to be practical.
A slight downside is that it makes the car a bit smokey on full throttle.
This is where I got mine - http://shop.grahamgoode.com/range-rover-td...3160-p.asp Got - 2017 SDV8 Autobiography in Loire Blue
Post #177922 16th Mar 2013 4:21pm
I had mine done, would never NOT have it done now, its an amazing change.
I went to JE Engineering, like the fact they have so much experience and its not a plug in box job. Discovery 4 HSE
Post #177974 17th Mar 2013 9:42am
Phil.
As above. Used JE Engineering for my 3.6TDV8 and the results were great. Circa 5%-10% increase in MPG. Wave of torque to play with. See their web site for the numbers. I also had my current 4.4 TDV8 remapped by JE with similar results. Can't recommend it enough. MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #178099 17th Mar 2013 8:45pm
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
i too used to get black smoke on kick down after remap.
have been using BP ultima..get about 1mpg better. but the engine is smoother and very little black smoke. 2011 4.4 TdV8 Nara Bronze
Post #178113 17th Mar 2013 10:35pm
Phil.
I've never had black smoke with either JE remap. MY23 D350 HSE
Post #178120 17th Mar 2013 11:35pm
DMRR
All remaps will give something out the back - you can't make a diesel go better without giving it more fuel *WHEN* it needs it - my remap suits me - it will give out a puff on hard acceleration, but that's to be expected. Be warned though - a remap moves the engine out of the 'safe' envelope, so if you are going on the continent, a blufin might be better for you so you can remove it and then keep up with traffic without fear of turbo/manifold problems Smile
Remember it a warranty void. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #178122 17th Mar 2013 11:52pm
martin g
Thanks for the info will have a think on which way to go
Post #178249 18th Mar 2013 9:09pm
Phil.
I've never heard before that remap equals black smoke. And I've remapped a fair few vehicles and never seen any black smoke. I've had few flames out the back of a decatted remapped TVR Cerbera but that was planned Wink My remaps have either been bespoke to the vehicle or bespoke to the model, all from highly experienced specialst sources. I have never used a 'plug in' remap or boost device. Perhaps it's those devices that are being referred to here with regard to black smoke? So where is the evidence for this remap equals black smoke theory? MY23 D350 HSE
Post #178865 21st Mar 2013 1:41pm
A lot of standard diesels will smoke anyway but the smoke means that it is simply overfuelling, like flames from a petrol car its not good as your just wasting power at the end of the day.
It takes a lot of work so would possibly take a full day for a vehicle with lots of on road testing or ideally a private road where the higher gears and longer duration of high boost can be kept. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #178872 21st Mar 2013 2:03pm
Phil.
To clarify, the flames out the back of my Cerbera was on overun and agree it's not efficient but was fun at the time Very Happy
As for my RR remaps (3.6 and 4.4), they have been model specific, their development has involved many thousands of miles and hours of testing by experts before release. I'm not aware of any overfuelling issues with either remap which should result in reduced MPG, when quite the opposite happens and MPG improves.
My point is, I am not aware of any evidence that says all [diesel] remaps result in smoke out the back. MY23 D350 HSE
Post #178877 21st Mar 2013 2:19pm
Philip
Diesel smoke is just unburnt fuel. A properly mapped diesel should not be chucking smoke out.
I'd be a bit worried if a petrol car was making flames under load ...
Post #178880 21st Mar 2013 2:30pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
I think he meant the overrun, which can happen as the fuel map doesn't respond fast enough (common issue in Denso ECU's). It's not a massive waste either, only a few CC's here and there, and considering you'll probably be doing single-digit mpg when getting the crackles and flames it probably isn't your biggest concern Smile
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #178901 21st Mar 2013 3:14pm
supershuttle
I used BlueFin it's seems fine with a significant improvement in low down power but I only use the grunt occasionally, there is (as there always is any diesel including my unchipped previous new Audis and Mercs) extra particulate emission on full throttle. This is more noticeable at night in your mirror when illuminated by the headlights of the car you just passed Very Happy .
I got to say the fuel consumption seems slightly down generally but overall I'm pleased, JE was a bit too far for me to go even with all the positive comments about their remaps. For me it's simple if you want more out you have to put more in - fuel that is, otherwise Land Rover would do it - fuel economy and decent performance are the conflicting holy grails for modern car manufacturers and there is no magic bullet. Geoff
Post #178913 21st Mar 2013 3:58pm
