Home > Wheels & Tyres > TPMS - any way to check if its activated?
GraemeC
As above, I believe my MY2007 Vogue SE has TPMS
Is there any way I can check if my vehicle has TPMS and if its working? (i.e. not been disabled)
I'd rather not have to resort to deflating a tyre!
Thanks 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #177138 12th Mar 2013 11:48am
Look at your tyre valves. If they are standard rubber ones you donn;t have it, although I would bet you do on a VSE like mine.
Who cares if its not working? If you don't have the dash light blinking at you and "TMPS malfunction" type message, be thankful! Thumbs Up Discovery 4 HSE
Post #177145 12th Mar 2013 12:30pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Take the spare wheel out .... I'm pretty sure that will do it ..... Removing a road wheel will definatly do it, mine alarmed when I was changing rear wheel discs.
Post #177147 12th Mar 2013 12:33pm
ebajema
Spare wheel removal should send an alarm. I remember that in mine, but the alarm is probably only once (I had a flat recently) and the alarm didn't come up again. Other option is deflating the spare of course Wink MY 2010 5.0 SC Galway green and sand interior!!
Post #177152 12th Mar 2013 12:52pm
^ +1...whilst you're doing your weekly tyre pressure check, let some air out and see what happens... ... - .- -.
Post #177153 12th Mar 2013 1:00pm
+1
In fact, if you've never had an error message it may well be disabled. I wish I'd just disabled it rather than trying to keep it working. The most expensive useless feature there is.
Post #177164 12th Mar 2013 2:14pm
GraemeC
Ah, now I remember reading about TPMS and the metal valves - I have those!
I will let some air out of the spare (got a compressor in the boot so not a problem) and see what happens...
In the meantime, I'd like to think its all workings fine and thats why I've never had any silly bongs! 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #177169 12th Mar 2013 2:28pm
ebajema
Mine works very well and saved me from destroying a tire the other day. No false alarms and issues sofar although the batteries are getting to their life end around 8 year and that is pretty damn close Sad MY 2010 5.0 SC Galway green and sand interior!!
Post #177171 12th Mar 2013 2:33pm
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Be very gentle with them, particularly if they look corroded.
I went to top mine up, and whole valve came off with hose, instant deflation ... Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #177173 12th Mar 2013 2:59pm
taskam
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Same happened to me. I was told to use plastic valve caps as metal ones cause the corrosion on the stems. 2007 TDV8 Vogue SE Java Black
Post #177174 12th Mar 2013 3:07pm
