![]() | Home > Wheels & Tyres > TPMS - any way to check if its activated? |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
As above, I believe my MY2007 Vogue SE has TPMS
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Look at your tyre valves. If they are standard rubber ones you donn;t have it, although I would bet you do on a VSE like mine.
Spare wheel removal should send an alarm. I remember that in mine, but the alarm is probably only once (I had a flat recently) and the alarm didn't come up again. Other option is deflating the spare of course |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35545 ![]() ![]() |
^ +1...whilst you're doing your weekly tyre pressure check, let some air out and see what happens... ... - .- -.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7977 ![]() ![]() ![]() |
+1 In fact, if you've never had an error message it may well be disabled. I wish I'd just disabled it rather than trying to keep it working. The most expensive useless feature there is. |
Ah, now I remember reading about TPMS and the metal valves - I have those!
Mine works very well and saved me from destroying a tire the other day. No false alarms and issues sofar although the batteries are getting to their life end around 8 year and that is pretty damn close |
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 ![]() ![]() ![]() |
Be very gentle with them, particularly if they look corroded.
taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121 ![]() ![]() ![]() |
Same happened to me. I was told to use plastic valve caps as metal ones cause the corrosion on the stems. 2007 TDV8 Vogue SE Java Black |
