Home > Technical (L322) > Heater |
Have checked thru the search field before asking , just recently the heater in my FFRR ( friggin freezin range rover ) seems to take at least a 40 min drive to get some heat to come thru the front vents , Yet in the back within 5/10 mins the back air vents are warm and toasty ......
22nd Feb 2010 8:28pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6370 |
It should heat up quick Mick,
22nd Feb 2010 9:24pm |
Do you get the same problem when set to vents, rather than on Auto? When it's less than 7 degrees or something if on auto it will only ever send air to the screen to prevent fogging. |
23rd Feb 2010 9:00am |
Very very seldom do i use auto, mostly vents ....... ====================================
23rd Feb 2010 9:41am |
Really, why? Do you have a dog and bark yourself too? Occasionally I might have cold feet so will redirect it, but if it has an auto button I like to leave it on auto, i'm anal like that lol. I found the HEVAC in the P38 used much better logic (as well as far superior dual blowers) |
23rd Feb 2010 9:52am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3749 |
yes, I am the same as Mick, I never use the Auto function.
23rd Feb 2010 10:48am |
That is the default heat setting. Screen and feet, but when the engine is cold it will stay at the screen to save freezing your feet - So it's already trying to do what you're forcing it to do? From reading up, the vents are only used when its cooling when one would prefer cool air at face level. |
23rd Feb 2010 10:53am |
Macdaddy Member Since: 15 Oct 2009 Location: Preston, Lancashire Posts: 466 |
Dan you've cleared a couple of things up there for me.
23rd Feb 2010 11:07am |
Dan, if mine is set to Auto on a warm temperature and the face vents are open, then I get warm air coming out of them, hence I don't use auto and just direct warm air to the screen and my feet. Maybe they changed the spec on later vehicles - mine also has temp controls on the vents |
23rd Feb 2010 11:14am |
Maybe, what year is yours? |
23rd Feb 2010 11:28am |
07 |
23rd Feb 2010 11:55am |
Completely different then, they have extra face vents too so a completely different heater body is used and probably a different ECU logic. Does it still have the stupid thumbwheel that negates what the ATC is trying to do? |
23rd Feb 2010 11:58am |
If you mean the BMW derived temperature selector in the face level vents, yes the 07MY onwards still have that, I love that feature personally.
23rd Feb 2010 12:02pm |
