![]() | Home > Technical (L322) > Heater |
Have checked thru the search field before asking |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
It should heat up quick Mick,
Do you get the same problem when set to vents, rather than on Auto? When it's less than 7 degrees or something if on auto it will only ever send air to the screen to prevent fogging. |
Very very seldom do i use auto, mostly vents ....... ====================================
Really, why? Do you have a dog and bark yourself too? Occasionally I might have cold feet so will redirect it, but if it has an auto button I like to leave it on auto, i'm anal like that lol. I found the HEVAC in the P38 used much better logic (as well as far superior dual blowers) ![]() |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3759 ![]() ![]() |
yes, I am the same as Mick, I never use the Auto function.
That is the default heat setting. Screen and feet, but when the engine is cold it will stay at the screen to save freezing your feet - So it's already trying to do what you're forcing it to do? From reading up, the vents are only used when its cooling when one would prefer cool air at face level. ![]() |
Macdaddy Member Since: 15 Oct 2009 Location: Preston, Lancashire Posts: 466 ![]() ![]() |
Dan you've cleared a couple of things up there for me.
Dan, if mine is set to Auto on a warm temperature and the face vents are open, then I get warm air coming out of them, hence I don't use auto and just direct warm air to the screen and my feet. Maybe they changed the spec on later vehicles - mine also has temp controls on the vents |
Maybe, what year is yours? ![]() |
07 |
Completely different then, they have extra face vents too so a completely different heater body is used and probably a different ECU logic. Does it still have the stupid thumbwheel that negates what the ATC is trying to do? ![]() |
If you mean the BMW derived temperature selector in the face level vents, yes the 07MY onwards still have that, I love that feature personally.
