![]() | Home > Technical (L322) > headlamp failier whilst under speed at night |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 ![]() ![]() ![]() |
yes if just dip are on o there own, they both go out it i put the lever to main beam, the other ones come on as well and again after 17 sec they all go off at the same time for 2/3 sec then all come on again.
hi joe, i would if i were in uk, but i will get a total rip off here in france im afraid. they will just change everything in sight and charge you the earth unfortunately.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35643 ![]() ![]() |
Bob, this is going technical so i'll move it there...thanks for the warning . |
ok stan sorry about that |
well if it is that, then im happy with that even if it is around �300. |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Have you found the LCM yet? I would start with checking every connection to it, take them off then on again. Previously..
You could have a look at fuses 9,4 and 53 which are 5A, 5A and 30A respectively or even change them for piece of mind but I don't think you will find anything.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6766 ![]() ![]() ![]() |
How about this then - http://www.ebay.co.uk/itm/Range-Rover-L322...2a29486121
hi contraband, yes i have been given the whereabouts of the LCM, if is behind the A pillar by the drivers door. i havent looked at it yet as it was snowing like a bas |
you might consider buying a IIDTool which should give you an error code to work with...the only problem will be the time it takes for it to be delivered to you... ... - .- -.
firstly alanm3, thanks for that, makes things a bit cheaper |
I'm not sure about this but I think a replacement LCM, new or used, has to be programmed to the car using Testbook.
ok, thanks for that; nothing is easy is it |
hi everybody. sorry i did not continue with this post but i have had a some rather huge problems to deal with personally over the last few months and thankfully it is all now sorted out so i have not been on the net for several months.
