Home > Technical (L322) > headlamp failier whilst under speed at night |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 |
yes if just dip are on o there own, they both go out it i put the lever to main beam, the other ones come on as well and again after 17 sec they all go off at the same time for 2/3 sec then all come on again.
25th Feb 2013 8:48pm |
hi joe, i would if i were in uk, but i will get a total rip off here in france im afraid. they will just change everything in sight and charge you the earth unfortunately.
25th Feb 2013 8:52pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35318 |
Bob, this is going technical so i'll move it there...thanks for the warning . ... - .- -.
25th Feb 2013 9:02pm |
ok stan sorry about that |
25th Feb 2013 9:04pm |
well if it is that, then im happy with that even if it is around £300. its whether i just take the chance and change it or pay probably the same amount again for the guys here to tell me just that, and end up paying double bubble
25th Feb 2013 9:14pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Have you found the LCM yet? I would start with checking every connection to it, take them off then on again. Previously..
25th Feb 2013 9:20pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3976 |
You could have a look at fuses 9,4 and 53 which are 5A, 5A and 30A respectively or even change them for piece of mind but I don't think you will find anything.
25th Feb 2013 9:23pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6729 |
How about this then - http://www.ebay.co.uk/itm/Range-Rover-L322...2a29486121
25th Feb 2013 9:25pm |
hi contraband, yes i have been given the whereabouts of the LCM, if is behind the A pillar by the drivers door. i havent looked at it yet as it was snowing like a bas ard on sunday.
25th Feb 2013 9:36pm |
you might consider buying a IIDTool which should give you an error code to work with...the only problem will be the time it takes for it to be delivered to you... ... - .- -.
25th Feb 2013 9:40pm |
firstly alanm3, thanks for that, makes things a bit cheaper , thinking about this a bit more, would i need to have a garage program this before it would work or could i just unplug the old one and fit the new one
25th Feb 2013 9:47pm |
I'm not sure about this but I think a replacement LCM, new or used, has to be programmed to the car using Testbook.
25th Feb 2013 9:53pm |
ok, thanks for that; nothing is easy is it , ok guys i will have a check around the unit and its connections, check the fuses etc etc, and if nothing changes, see if i can find a garage that WILL put the testbook on it.
25th Feb 2013 9:58pm |
hi everybody. sorry i did not continue with this post but i have had a some rather huge problems to deal with personally over the last few months and thankfully it is all now sorted out so i have not been on the net for several months.
28th Jul 2013 11:12am |
