Home > Technical (L322) > Steering Wheel Judder @ 55mph
jonny142
United Kingdom 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
Hi Guys,
Whilst driving on the M1 today, I noticed that there was a Judder in my steering wheel between 55/60mph...
The wheel was fine upto 55 and fine over 60... I wondered if anyone could suggets what may cause this before I take it to the stealer... ?
Cheers
Jonny 4.4 V8 Vogue Adriatic - Cream leather
Post #13314 17th Feb 2010 4:47pm
M44K TS
Might be worth checking the basics like is a wheel out of balance, tyre pressures etc.
Then if it's not that, jack it up and give the wheels a good push and pull to check for play in the bushes/bearings.
That would be my thoughts anyway.
Post #13315 17th Feb 2010 5:07pm
daveo
yep, sounds good advice, check from the unts up, but sounds like a balancing issue..... V8 facelift Range Rover Autobiography 22" wheels.
Post #13317 17th Feb 2010 5:52pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Yep, I had a bit of judder once, funnily, around the same speed as yourself, and mine was due to the nearside front tyre pressure being about 5 lbs less than the offside. Added air and all OK (I don't have the tpms option as I assume that would have picked up on the lower pressure).
Steve Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #13327 17th Feb 2010 9:05pm
Stocky
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Fuji White
Just a point to remember for those with TPMS, it won't pick up very slow leaks in pressure, it has to be reasonably fast. I lost 6lbs or so in both fronts between services and got no warning. picked it up because of slightly uneven wear. You still need to check them now and then!
Post #13336 18th Feb 2010 7:24am
Macdaddy
2003 Range Rover Autobiography 4.4 V8 Java Black
Another vote for balancing ....
55-60 seems weirdly to be the speed that always highlights this issue! TDV8 HST Sport **Current**
4.4 V8 Autobiography and 22" wheels **Gone**
Post #13337 18th Feb 2010 7:44am
Vogue
a warped brake disc also shows up like this, only takes a few thou and thats it makes horrible shakes at these speeds until you drive through it.
Heavy towing and use of brakes on steep inclines overheats the disc and causes warping, doesn't seem to affect brake efficiency just gives you the shakes Neutral
Post #13338 18th Feb 2010 9:39am
SAppie
flawed tyres.....
I recently had a full set of Pirelli Scorpion tyres fitted to our Disco3, and then had the exact same symptoms as you are experiencing. I went back on 4 seperate occasions to have them rebalance all 4 tyres, to no avail. They then replaced all 4 new tyres with another 4 new tyres, and rebalanced, and its been 100% since.
Just goes to show that even premium tyres are not 100% perfect from the factory. Just a thought.......
Post #13356 18th Feb 2010 3:57pm
jonny142
Well, after several trips to the garage, and a new set of front tyres, the ride was much better, but not right... I ended up having a small local tyre fitter looking into it and they sorted it out..... stick on nickle balancing on the rear wheels....... Thumbs Up 4.4 V8 Vogue Adriatic - Cream leather
Post #14816 13th Mar 2010 8:41am
Wheel wobble will generally present itself at a certain speed of revolution as you experienced (I've always noticed its about 60mph) or upon braking.
9 times out of 10 its wheel balancing. Most times this will happen after you've had new tyres and they've just been rebalanced, I don't think they are ever as well balanced as when alloys and tyres are brand new. It's a constant bugbear of mine, I once took a car in to be balanced about 5 times before it solved the issue. You have to wonder just why the blokes can't do it first time every time.
if Ken was still posting on the forum I'm sure he'd give us some insights.
(Where HAS Ken gone? Question ) Discovery 4 HSE
Post #14818 13th Mar 2010 9:31am
M44K TS
My van has just had it's MOT and needed a front tyre, now has a very annoying wobble at 80-85mph, (white van man cruising speed)
I don't think tyre fitters can be bothered to balance them properly, lazy sods. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #14819 13th Mar 2010 9:42am
