![]() | Home > Technical (L322) > Steering Wheel Judder @ 55mph |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
Might be worth checking the basics like is a wheel out of balance, tyre pressures etc.
yep, sounds good advice, check from the unts up, but sounds like a balancing issue..... V8 facelift Range Rover Autobiography 22" wheels.
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
Yep, I had a bit of judder once, funnily, around the same speed as yourself, and mine was due to the nearside front tyre pressure being about 5 lbs less than the offside. Added air and all OK (I don't have the tpms option as I assume that would have picked up on the lower pressure).
Stocky Member Since: 13 Oct 2009 Location: New Forest Posts: 142 ![]() ![]() ![]() |
Just a point to remember for those with TPMS, it won't pick up very slow leaks in pressure, it has to be reasonably fast. I lost 6lbs or so in both fronts between services and got no warning. picked it up because of slightly uneven wear. You still need to check them now and then! |
Macdaddy Member Since: 15 Oct 2009 Location: Preston, Lancashire Posts: 466 ![]() ![]() |
Another vote for balancing ....
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 ![]() ![]() |
a warped brake disc also shows up like this, only takes a few thou and thats it makes horrible shakes at these speeds until you drive through it.
SAppie Member Since: 08 Feb 2010 Location: Berkshire Posts: 159 ![]() ![]() |
I recently had a full set of Pirelli Scorpion tyres fitted to our Disco3, and then had the exact same symptoms as you are experiencing. I went back on 4 seperate occasions to have them rebalance all 4 tyres, to no avail. They then replaced all 4 new tyres with another 4 new tyres, and rebalanced, and its been 100% since.
jonny142 Member Since: 29 Oct 2008 Location: Sheffield Posts: 28 ![]() ![]() ![]() |
Well, after several trips to the garage, and a new set of front tyres, the ride was much better, but not right... I ended up having a small local tyre fitter looking into it and they sorted it out..... stick on nickle balancing on the rear wheels....... |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 ![]() ![]() ![]() |
Wheel wobble will generally present itself at a certain speed of revolution as you experienced (I've always noticed its about 60mph) or upon braking.
My van has just had it's MOT and needed a front tyre, now has a very annoying wobble at 80-85mph, (white van man cruising speed)
