Home > Technical (L322) > Squeal from fan motor when cornering/hitting potholes |
I've not had this and I have a high mileage (120K) car and I also like to corner enthusiastically occasionally. I'd be interested to see if it is this, I just did a quick search on the BMW boards but only came up with a post about the serp' belt. It drives the Alt and the PS pump so under heavy load from turning and heavy electrical load he got a noise. Could it be that?
26th Jan 2010 4:58pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
sound like worn bearing spindle also , isnt the blower motor under the scuttle bit that the cabin filter sits in under the bonnet
26th Jan 2010 7:33pm |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2031 |
Filter housing is eay to remove, just a couple og nuts |
26th Jan 2010 7:35pm |
Stuart528 Member Since: 14 Nov 2009 Location: North West Posts: 25 |
Thanks all. Good point - better work out where this darn fan is...
29th Jan 2010 11:04pm |
