Home > Technical (L322) > Squeal from fan motor when cornering/hitting potholes
Stuart528
United Kingdom 2003 Range Rover Vogue SE 4.4 V8 Java Black
Anyone had this before? When I corner too enthusiastically, or hit speed bumps/potholes, my heater fan motor starts to squeal. It goes away after 10 seconds or so, and also reducing or increasing the blower speed seems to stop it squealing.
I have had this on other cars, pretty sure it is a worn blower motor/bearing.
Does anyone know if this is a common BMW part, or RR specific? I have 03 model 4.4 Vogue. I feel a dashboard removal weekend coming on... again...
Cheers, Stuart.
Post #11713 26th Jan 2010 3:01pm
dan_uk_1984
I've not had this and I have a high mileage (120K) car and I also like to corner enthusiastically occasionally. I'd be interested to see if it is this, I just did a quick search on the BMW boards but only came up with a post about the serp' belt. It drives the Alt and the PS pump so under heavy load from turning and heavy electrical load he got a noise. Could it be that?
Sounds like your diagnosis is already quite accurate though, in which case could you take some photo's of the dash removal? Would be great to have them on file for future jobs!
Dan
Post #11719 26th Jan 2010 3:58pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
sound like worn bearing spindle also , isnt the blower motor under the scuttle bit that the cabin filter sits in under the bonnet
would hate for you to strip all the inside out only to find its not there Rolling with laughter that would be a proper Censored Rolling with laughter onto no6 Range Rover
Everyone needs a hobby
Post #11761 26th Jan 2010 6:33pm
nbunney
Filter housing is eay to remove, just a couple og nuts Thumbs Up
Post #11763 26th Jan 2010 6:35pm
Stuart528
Thanks all. Good point - better work out where this darn fan is... Confused
Mind you I had a lot of the dash apart to refit my TV screen, actually wasnt too hard.
I will certainly take some pics if I do this, but to be honest it is very intermittent right now and my wife would kill me if I spend a saturday "playing" with the car for something minor like this instead of being a helpful husband and father...
Post #11962 29th Jan 2010 10:04pm
