Home > Technical (L322) > Perm jump start connector |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Wouldn't it be easier to modify the standard jump points to get a better connection? Think their 13mm nuts. You could get some fabricated with flat plate type things to allow standard cables to get a better connection? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
10th Dec 2012 9:37pm |
oldcro Member Since: 17 Mar 2012 Location: Shetland Posts: 359 |
Teaching granny to suck eggs here, but when connecting cables from a doner vehicles battery leave for 10 to 15 minutes with doner engine running. Then switch on FFRR and try to start having built up some charge in the FFRR's battery, takes some load off the cables if under sized. |
10th Dec 2012 9:38pm |
Only available on the older pre 2007 models.... |
11th Dec 2012 11:12am |
The -ve post is still there isn't it in later models though?
11th Dec 2012 11:28am |
Yes |
11th Dec 2012 11:43am |
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 |
all very helpful replies but i've no positive post for jump starting,was never there and yes I know what it looks like and where it should be
11th Dec 2012 10:39pm |
I agree rath
11th Dec 2012 10:52pm |
yip am certainly thinking about doing that but was wondering if I could improve upon it at all.looks like I will just go with the easy option and get the missing positive jumping post parts from the stealers |
11th Dec 2012 10:55pm |
I think if your going to that trouble you should go the whole hog
12th Dec 2012 8:41am |
You need some Anderson SB series 350 AMP connectors as fitted to electric forklift trucks
12th Dec 2012 8:48am |
Like this John?
12th Dec 2012 9:17am |
That's the sort of thing Will, They are used for the power supply of electric forklift trucks and extremely robust |
12th Dec 2012 9:19am |
Im guessing the bits they picture include the male and female parts (calm down Mick!) and not just one side of the connector?
12th Dec 2012 9:21am |
There are several different types of connectors, but basically yes you will have a male and female connector |
12th Dec 2012 9:30am |
