Home > Technical (L322) > Perm jump start connector |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
I can see some benefit of doing this but what is so hard about lifting the bonnet and connecting jump clamps to the the two connector posts provided in the FFRR ? They are easy to get to, and no special connectors needed? .
8th Dec 2012 3:43pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3825 |
I charge mine using the towing electrics socket on the back - seems to work fine Obviously no good for jump start but fine for c- tek 7 amps and I don't need to open the bonnet or even the car Geoff |
10th Dec 2012 9:59am |
The main reason I want something along these lines is to make jumping of other vehicles that much easier when I need to it. Knowing my luck I would install it and never need it again
10th Dec 2012 10:08am |
T111RDY Member Since: 21 May 2012 Location: Dunbar Posts: 187 |
Is it not something like this you want?!?
10th Dec 2012 10:57am |
Although possibly only one..... l:OolΞΞΞΞΞΞloO:l
10th Dec 2012 11:04am |
A bit more realistic...!
10th Dec 2012 11:08am |
They are a bit pricey And still jump posts that are close together as well
10th Dec 2012 11:20am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
The only trouble with externally mounted connectors of any type is the risk of vandalism.
10th Dec 2012 11:34am |
Would a suitable fuse not cover this though??
10th Dec 2012 12:04pm |
Thsi should do the job.
10th Dec 2012 12:06pm |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 |
Do you have any idea how long it takes to pop the bonnet and lift it ???? He's a busy man. |
10th Dec 2012 6:07pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Will
10th Dec 2012 7:45pm |
Ha ha a Jeeves!! If the divorce goes well I could have the ex stuffed in the boot to perform such duties but it might be too good for her lol!!
10th Dec 2012 8:23pm |
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 |
I cant afford a Jeeves as the rangie has bled me dry
10th Dec 2012 9:25pm |
