Home > Technical (L322) > Brake discs and pads |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2938 |
I'm just about to tackle mine. What model/year is yours? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
17th Jan 2010 1:50pm |
Macdaddy Member Since: 15 Oct 2009 Location: Preston, Lancashire Posts: 466 |
Checked mine and i think i'l be changing mine soon too.
17th Jan 2010 2:18pm |
rocksteadyeddie Member Since: 15 Jan 2010 Location: London Posts: 38 |
I've got a 2005 SC. I can't imagine it's that difficult but always good to have some pics! |
17th Jan 2010 3:04pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
dont forget to clamp the rubber hose with the correect tool , then undo your bleed nipple befour you squeeze the pistons back and squeeze the fluid into a suitable container as a lot of cars can be damaged when you push the fluid back into the reservoir keep it flowing the one way guys when all bvack together quick bleed of the front brakes and your sorted as youll have removed any air in the calipers , youll have removed any moisture in the fluid and lubed your bleed nipples
17th Jan 2010 4:22pm |
Alias Member Since: 14 Oct 2009 Location: Zurich Posts: 70 |
Are they any other breaks for the 2007 s/c? Maybe bigger rear one from Brembo? |
18th Feb 2010 4:18pm |
Right, I did mine today front and rear and it was easy.
20th Feb 2010 4:53pm |
