Home > Technical (L322) > Brake discs and pads
rocksteadyeddie
Newbie here Very Happy
I have done my own brakes for a while now so have a broad idea of what I am doing but this will be the first time I have done the RR. Does anyone had any tips / advice on doing the front ones on a FFRR SC as the devil is always in the detail when doing these sorts of jobs? Any pointers to an online instructional would be great too as I don't seem to be able to find one.
I have tried to avoid the ultimate newbie crime of reposting and have done a reasonable search but can't find anything.
Thanks in advance
RSE
Post #11131 15th Jan 2010 10:41pm
Andy
I'm just about to tackle mine. What model/year is yours? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #11181 17th Jan 2010 12:50pm
Macdaddy
2003 Range Rover Autobiography 4.4 V8 Java Black
Checked mine and i think i'l be changing mine soon too.
Ive done pads/discs on every car ive owned so hoping the FFRR is as straight forward! TDV8 HST Sport **Current**
4.4 V8 Autobiography and 22" wheels **Gone**
Post #11183 17th Jan 2010 1:18pm
rocksteadyeddie
I've got a 2005 SC. I can't imagine it's that difficult but always good to have some pics!
Post #11185 17th Jan 2010 2:04pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
dont forget to clamp the rubber hose with the correect tool , then undo your bleed nipple befour you squeeze the pistons back and squeeze the fluid into a suitable container as a lot of cars can be damaged when you push the fluid back into the reservoir keep it flowing the one way guys when all bvack together quick bleed of the front brakes and your sorted as youll have removed any air in the calipers , youll have removed any moisture in the fluid and lubed your bleed nipples Thumbs Up
this is very rough guidlines not complete step by step Rolling with laughter Thumbs Up Thumbs Up onto no6 Range Rover
Everyone needs a hobby
Post #11189 17th Jan 2010 3:22pm
Alias
Switzerland
Are they any other breaks for the 2007 s/c? Maybe bigger rear one from Brembo?
Post #13354 18th Feb 2010 3:18pm
Andy
Right, I did mine today front and rear and it was easy.
Fronts- wheels off, look at the rear of the caliper and you'll see two 16mm bolts. These hold the caliper on. Remove them and take off complete caliper. You can then replace the pads easily. The disc is held on by a small Allen bolt which came out easy on mine.
My fronts were badly worn and I had to replace the wear indicator (euro car parts £12.50)-I only found out today that there's only one on the front, so I'll need to take the other one back for a refund!
Refitting is simply a reverse of the above.
Rears- pretty much the same as the fronts, apart from the handbrake shoes inside the rear disc. move the disc so that the adjuster hole is at the bottom and using A screwdriver to flick the adjuster, release the shoes enough to allow removal of the disc (see handbrake adjustment thread)
again, refitting is a reverse of removal. Total time - 3 hrs with tea breaks, chatting, clean-up etc. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #13441 20th Feb 2010 3:53pm
