Home > Technical (L322) > Faulty heated windscreen drivers side, anyone fixed it?
dirtyharry
I've seen several threads on this but not yet found a solution to the problem (apart from the obvious of a total screen replacement, courtesy of the insurance company plus an excess payment!).
The driver's side doesn't clear, but the passenger side does. There are suggestions of there being 2 fuses, one for each side of the screen, but I can only find the one relay, which I assume controls the whole screen, located behind the passenger side fascia. I'm guessing that because the passenger screen clears, then the relay isn't faulty.
There's also talk of poor earthing of the wires where the screen meets the bodywork (?), but I can't see how to access them.
Has anyone identified where the problem lies and actually managed to successfully fix it? Or is a replacement screen the only solution?
Any help always appreciated Wink Cheers
Greg
Go ahead punk, make my day........
Previous vehicles:-
Far too many to list (in excess of 45!)
Post #152032 19th Nov 2012 12:44pm
Most likely need a new screen Thumbs Up
Post #152046 19th Nov 2012 2:01pm
Windscreen Dave
United Kingdom 2003 Range Rover Vogue Td6 Alveston Red
I would concur and suggest a new windscreen is required.
Post #152081 19th Nov 2012 4:19pm
mjdronfield
According to RAVE, there is one relay feeding 2 elements.
So it looks like you either have a faulty element, in which case a new screen will be needed, or the element on the drivers side isn't getting a feed from the relay. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #152091 19th Nov 2012 4:43pm
mjdronfield
Looks like the connection for the screen is behind the A pillar trim, at the top of the dash RH and LH for the respective sides ;
If its getting power, and the screen is not clearing, then I'm afraid you have your answer....... Sad 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #152094 19th Nov 2012 4:51pm
i wonder why its always the drivers screen not the passenger side that breaks down.. ... - .- -.
Post #152095 19th Nov 2012 4:58pm
dirtyharry
Yep, I noticed that too from the threads I found. Confused Cheers
Greg
Previous vehicles:-
Post #152097 19th Nov 2012 5:15pm
mjdronfield
Perhaps that side gets more wear, as the driver is always in the car looking through it Rolling with laughter 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #152098 19th Nov 2012 5:15pm
dirtyharry
Thanks for that Mark, I'll test it tomorrow but I fear the worst....... Sad Cheers
Greg
Previous vehicles:-
Post #152100 19th Nov 2012 5:17pm
dirtyharry
Laughing Laughing Laughing Cheers
Greg
Previous vehicles:-
Post #152101 19th Nov 2012 5:24pm
Andy
Mine is the same. Passenger clears in no time, but nothing on my side. At least I know where the feeds are now.
By removing the A pillar trim, it's not going to disturb the airbag curtain is it? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #152851 23rd Nov 2012 9:04am
Windscreen Dave
You can remove the a pillar trim easily the airbag logo at top prises off and then reveals torque screw behind it. Just be careful when replacing as the pillar locator on the trim can sometimes snag the airbag and the trim will not sit properly.
Post #152997 23rd Nov 2012 5:56pm
Porridge
Ireland 2007 Range Rover Vogue TDV8 Java Black
Hey Greg.
Did that work for you, or is it a Screen Replacement job?
I have the same problem.
Dave G FullFat Porridge
2007 TDV8 Vogue.
2005 VTR 1000 SP2.
2012 Hayabusa.
2006 K1200 GT
1988 ur quattro.
Post #166311 21st Jan 2013 3:44pm
dirtyharry
Hi Dave
I'm afraid I never got as far as checking the wiring as it turns out I do need a new windscreen. It's definitely getting power on the drivers side but I've got several patches where the heated filaments work and other areas where they don't. So I'm going to have to wait until I can get a new windscreen under the insurance. Sad Cheers
Greg
Previous vehicles:-
Post #166323 21st Jan 2013 4:24pm
This'll fix any heated screen problems Whistle Whistle Whistle
Post #166324 21st Jan 2013 4:27pm
