Home > In Car Electronics (L322) > Replacing cigar lighter with USB charging socket |
Just a bit of info which might prove useful to some. If, like us, you have a load of stuff which needs USB charging facilities, these units I found on Amazon have a couple of advantages over the plug in (variable quality) things.
4th Nov 2012 12:37pm |
Well, I have 2 of the plug in things which are allegedly rated at 1 amp (1000mA). One will charge the IPAD and the other won't so a proper 1 amp will by the look of things, but if it's 1 amp max as a surge rating then the true RMS output is likely to be about 700mA which isn't enough.
4th Nov 2012 1:59pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
4th Nov 2012 2:04pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3168 |
cheers guys! Sold! decided to give the cheapies a miss!
4th Nov 2012 2:22pm |
And how much of a pain was it to fit? IIRC the cigar lighter comes out from under the gear lever cover? .
4th Nov 2012 11:33pm |
OK, I haven't done the car yet. Put one in the caravan and still deciding which one to replace in the car out of the 4 available up front.
5th Nov 2012 6:46am |
Pitsnow Member Since: 17 Jul 2012 Location: Cleethorpes Posts: 183 |
Blue Sea also make a plug with the same power rating as the socket:
5th Nov 2012 7:16am |
I found the best and easiest solution was a Belkin USB-Accessory socket.
5th Nov 2012 2:28pm |
