![]() | Home > In Car Electronics (L322) > Replacing cigar lighter with USB charging socket |
Just a bit of info which might prove useful to some. If, like us, you have a load of stuff which needs USB charging facilities, these units I found on Amazon have a couple of advantages over the plug in (variable quality) things.
Well, I have 2 of the plug in things which are allegedly rated at 1 amp (1000mA). One will charge the IPAD and the other won't so a proper 1 amp will by the look of things, but if it's 1 amp max as a surge rating then the true RMS output is likely to be about 700mA which isn't enough.
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3200 ![]() ![]() |
cheers guys! Sold! decided to give the cheapies a miss!
And how much of a pain was it to fit? IIRC the cigar lighter comes out from under the gear lever cover? .
OK, I haven't done the car yet. Put one in the caravan and still deciding which one to replace in the car out of the 4 available up front.
Pitsnow Member Since: 17 Jul 2012 Location: Cleethorpes Posts: 183 ![]() ![]() ![]() |
Blue Sea also make a plug with the same power rating as the socket:
I found the best and easiest solution was a Belkin USB-Accessory socket.
