Home > Technical (L322) > Screen Washer Jets
ay4alex
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Screen Washer Jets
Hi guys, bit of an issue, especially with the current temperature Crying or Very sad the passenger side screen washer jet has stopped functioning. I've drained the old screen wash (its been low for ages) and then replaced it with a 50/50 dilution (rated to -9DegreesC) and mixed in almost boiling water, and still no luck. heated up the jet, heated up the wiring for the heater and the fluid pipe. Struggling for more ideas.. maybe a faulty unit? Sad
Thanks Alex 2008 Vogue TDV8 Java Black
2008 Puma TDCi 110 DC
19?? Defender soft top V8
Post #10798 8th Jan 2010 3:49pm
itguy
2006 Range Rover Vogue Td6 Cairns Blue
They're only a fiver - stick a new one in FFRR TD6 06MY. Cairns Blue, Blue Hide. LR 7 Spoke 20" Wheels, S/C Grill and Vents. Privacy Glass and Side Steps
Post #10840 9th Jan 2010 9:23am
The Flying Scot
Scotland 2012 Range Rover Westminster 4.4 V8 Fuji White
or if you're bored and fancy tinkering around, then remove the jet and dismantle it. You'll find the little red non return valve will be stuck so simply remove it and the re-fit the jet. hey presto one working jet! 2011 Range Rover TDV8 4.4 Vogue SE
2007 Range Rover TDV8 Vogue (Sold)
2004 Range Rover Vogue TD6 (Sold)
Post #11127 15th Jan 2010 9:59pm
rocksteadyeddie
Judicious use of a pin down the hole can solve all sorts of problems.
Post #11145 16th Jan 2010 5:11pm
