![]() | Home > Technical (L322) > Screen Washer Jets |
itguy Member Since: 08 Dec 2009 Location: Melton Mowbray, UK Posts: 113 ![]() ![]() |
They're only a fiver - stick a new one in FFRR TD6 06MY. Cairns Blue, Blue Hide. LR 7 Spoke 20" Wheels, S/C Grill and Vents. Privacy Glass and Side Steps |
The Flying Scot Member Since: 09 Apr 2009 Location: Surrey Posts: 77 ![]() ![]() ![]() |
or if you're bored and fancy tinkering around, then remove the jet and dismantle it. You'll find the little red non return valve will be stuck so simply remove it and the re-fit the jet. hey presto one working jet! 2011 Range Rover TDV8 4.4 Vogue SE
rocksteadyeddie Member Since: 15 Jan 2010 Location: London Posts: 38 ![]() |
Judicious use of a pin down the hole can solve all sorts of problems. |
