Home > Technical (L322) > Air Compressor Strip down
Page 2 of 3 <123>
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Kind and best regards for this recomment... first the kit seems not cheap, but at the end of the day it is the only way for the suspension-blower-power... L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #150731 11th Nov 2012 10:36pm
Please note this is for the earlier models, IE 2002-2005 as with the facelift there is a change over to a different unit Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #157625 15th Dec 2012 5:14pm
Paulhh
Scotland 2002 Range Rover Vogue 4.4 V8 Epsom Green
Trist, Great write up.
Can I ask what the output pressure should be? I see yours is now at 11 bar and it was mentioned that there was a software update limiting output pressure to 9 bar.
My issue is, I have a Susp inactive error. I got it read with an autologic and 2 errors appeared, first was it was taking the compressor too long to get to pressure and the second was a front right height sensor. when we looked at the outputs from the sensors, the front right wasn't too far off and it did change when rocking. We then did the software update which allowed the compressor to run for longer without generating an error. This worked for a few trips (3) but now error back. My next move was thinking maybe the front right airbag was the furthest from the compressor so taking too long to inflate. This in my head now makes me think that the compressor is starting to fail.
Can you remove the air pipe and put your thumb over the end to see what kind of pressure there is? 11 bar is 160 psi which I guess would be significant, would this be a reasonable test? 2002 Vogue Epsom Green with Ivory Leather.
Discover 2 V8
Discovery 2 TD5
Discovery 1 V8
Audi S4 (2005)
Audi S4 (2000)
Post #169459 2nd Feb 2013 8:43am
ebajema
Paul, you may be looking at the first signs of suspension airbag failure. This is how mine started going. The front right back had multiple longitudinal cracks in it. I suggest to get the car to offroad height, switch everything off and listen for air escaping. Probably wise to go to a very quiet place. On mine the cracks were "inside the fold" of the bag, so not visible until we removed the struts for front wheel bearing and suspension arm rubber change out.
Then the "too long to raise" issue made sense. MY 2010 5.0 SC Galway green and sand interior!!
Post #169464 2nd Feb 2013 9:28am
Paulhh
Cheers for that.
The only thing I can add is that I left the car for 2 1/2 weeks with the error but the suspension didn't droop so I don't think it's the airbag although I will do the check. Check will have to be at normal height as I can't adjust the height due to the error code 2002 Vogue Epsom Green with Ivory Leather.
Discover 2 V8
Discovery 2 TD5
Discovery 1 V8
Audi S4 (2005)
Audi S4 (2000)
Post #169476 2nd Feb 2013 10:18am
ebajema
If it didn't sink for that long that it is unlikely to be any sort of leak, so you are probably right about the compressor. MY 2010 5.0 SC Galway green and sand interior!!
Post #169477 2nd Feb 2013 10:19am
Meerbusch
Thanks again for the perfect Pictures, Need them for a client from me...
rgs, Meerbusch L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #189575 21st May 2013 10:47am
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
Help!
Replacing the air compressor today and unsure as to whether the actual air pipe leading from the compressor to the valve just pulls off.
I can see a silver washer where the existing pipe goes into the valve but turning this with pliers just turns and turns.
So my question is does the pipe pull off? I've tried pulling but it isn't moving.... 2009 Vogue TDV8 Nara Bronze
2002 Vogue V8 Zambezi Silver
1986 90 Pick up Deep Bronze Green
1978 Series III SWB Deep Bronze Green
Post #194422 15th Jun 2013 1:26pm
They are all push fit. You need to push the color back into the fitting then pull the pipe out. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #194430 15th Jun 2013 1:56pm
Rich86
Thanks have one this and thepipme slipped off.
One more question...I've replaced the compressor and having started th engine none of the orange suspension lights on the dash are on,not even roand height.
Is this normal and do I now need to get the dashboard error message reset so that the car knows this is a new compressor and will this then pump air in to get it working again? 2009 Vogue TDV8 Nara Bronze
Post #194438 15th Jun 2013 2:26pm
Start engine. Turn steering to full left then full right then back to centre and wait. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #194441 15th Jun 2013 3:22pm
Rich86
I've done that but still no lights... 2009 Vogue TDV8 Nara Bronze
Post #194460 15th Jun 2013 5:09pm
try driving around , it should hopefully all rest itself. ... - .- -.
Post #194461 15th Jun 2013 5:20pm
Rich86
Ok stan will do. Do you think the message will disappear too or will that need to be reset? 2009 Vogue TDV8 Nara Bronze
Post #194475 15th Jun 2013 7:34pm
see what happens after the drive......you might have to disconnect the battery for while after that.. ... - .- -.
Post #194482 15th Jun 2013 8:28pm
Page 2 of 3 <123>
