Home > Technical (L322) > Air Compressor Strip down |
Please note this is for the earlier models, IE 2002-2005 as with the facelift there is a change over to a different unit FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
15th Dec 2012 4:14pm |
Paulhh Member Since: 23 Dec 2012 Location: Carrbridge Posts: 143 |
Trist, Great write up.
2nd Feb 2013 7:43am |
Paul, you may be looking at the first signs of suspension airbag failure. This is how mine started going. The front right back had multiple longitudinal cracks in it. I suggest to get the car to offroad height, switch everything off and listen for air escaping. Probably wise to go to a very quiet place. On mine the cracks were "inside the fold" of the bag, so not visible until we removed the struts for front wheel bearing and suspension arm rubber change out.
2nd Feb 2013 8:28am |
Cheers for that.
2nd Feb 2013 9:18am |
If it didn't sink for that long that it is unlikely to be any sort of leak, so you are probably right about the compressor. MY 2010 5.0 SC Galway green and sand interior!!
2nd Feb 2013 9:19am |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 316 |
Thanks again for the perfect Pictures, Need them for a client from me...
21st May 2013 9:47am |
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 |
Replacing the air compressor today and unsure as to whether the actual air pipe leading from the compressor to the valve just pulls off.
15th Jun 2013 12:26pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
They are all push fit. You need to push the color back into the fitting then pull the pipe out. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
15th Jun 2013 12:56pm |
Thanks have one this and thepipme slipped off.
15th Jun 2013 1:26pm |
Start engine. Turn steering to full left then full right then back to centre and wait. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
15th Jun 2013 2:22pm |
I've done that but still no lights... 2009 Vogue TDV8 Nara Bronze
15th Jun 2013 4:09pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
try driving around , it should hopefully all rest itself. ... - .- -.
15th Jun 2013 4:20pm |
Ok stan will do. Do you think the message will disappear too or will that need to be reset? 2009 Vogue TDV8 Nara Bronze
15th Jun 2013 6:34pm |
see what happens after the drive......you might have to disconnect the battery for while after that.. ... - .- -.
15th Jun 2013 7:28pm |
