![]() | Home > Technical (L322) > Fitting Telestart Heater control |
GTJones Member Since: 23 Aug 2012 Location: Carmarthenshire Posts: 35 ![]() ![]() ![]() |
Hi Everyone
spanner Member Since: 05 Jun 2011 Location: uk Posts: 134 ![]() |
plug and play |
When I fit the unit will I also get the aux heater displayed as it only shows aux ventilation at the moment? My car is a 2002 vogue Thanks Gary |
no you need to program the aux heater |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
This is exactly where I'm at............have a Td6 with FBH, but only Aux Ventilation available on the menu, no Aux Heat............
Managed to buy a Telestart & remote but i will be |
noddy5vogue Member Since: 21 Jan 2011 Location: Blackpool Posts: 38 ![]() ![]() ![]() |
I second that think i may have found cabling clipped to front of fuse board but no aerial |
Hi Noddy
Hi Gary,
Hi Steve
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
HAve you got it working yet? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Hello Gents. My name is Paul and I own an L322 VSE TDV8 on a 57 plate that has the Aux Heater fitted.
Hi Paul
Thanks Axle.
UPDATE- Axle....did what you said and its working a treat...many thanks! - Paul |
