Home > Technical (L322) > Fitting Telestart Heater control
Andy
Sorry to resurrect this thread but does anyone have a wiring diagram for the T60 and T91 so that I can connect the wires together?
I've emailed Webssto and they are either thick or are misreading my emails. All they keep saying is the t91 has a different plug and a t60 harness won't plug and play. I KNOW THIS!!
They then sent my emails to Holland and I had the same response!
Post #305856 17th Jan 2015 5:00pm
google 'webasto t91 wiring diagram' Thumbs Up ... - .- -.
Post #305862 17th Jan 2015 5:11pm
Andy
It's the T60 one I need as well.
Post #305864 17th Jan 2015 5:12pm
322BLL
Estonia
Searched but didn't quite find the answer about what is needed to have like factory park heat.
Telestart module
Telestart fob
Extra valve?
Programming
Edit: great pdf file in wiki to get all info needed! Thanks!
Post #512520 18th Apr 2019 3:34pm
Andy
I’ve got a receiver that I bought for my 02 TD6. I’m not sure if it’s the correct one as I never got round to fitting it. I can find out though. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #512524 18th Apr 2019 3:57pm
322BLL
Estonia
Andy, would be great if you could Thumbs Up
I understand the newer telestart receivers have bigger working range but also need different plug+soldering.
Post #512648 20th Apr 2019 9:21am
