![]() | Home > Technical (L322) > Fitting Telestart Heater control |
GTJones Member Since: 23 Aug 2012 Location: Carmarthenshire Posts: 35 ![]() ![]() ![]() |
Hi Everyone
spanner Member Since: 05 Jun 2011 Location: uk Posts: 134 ![]() |
plug and play |
When I fit the unit will I also get the aux heater displayed as it only shows aux ventilation at the moment? My car is a 2002 vogue Thanks Gary |
no you need to program the aux heater |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7905 ![]() ![]() ![]() |
This is exactly where I'm at............have a Td6 with FBH, but only Aux Ventilation available on the menu, no Aux Heat............
Managed to buy a Telestart & remote but i will be |
noddy5vogue Member Since: 21 Jan 2011 Location: Blackpool Posts: 38 ![]() ![]() ![]() |
I second that think i may have found cabling clipped to front of fuse board but no aerial |
Hi Noddy
Hi Gary,
As parts are hard to find used and very expensive new, I'd just go with a window antenna behind the C-pillar cover or similar. Webasto window antennas can be seen in the remote reciever pics above - the flat rectangular bit with the wire coming out (the one in the t90 pic is blue). TBH, tho, if you are not interested in maximum range, try various lengths of wire in the antenna connector... ![]() ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
Hi Steve
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
HAve you got it working yet? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Hello Gents. My name is Paul and I own an L322 VSE TDV8 on a 57 plate that has the Aux Heater fitted.
Hi Paul
Thanks Axle.
UPDATE- Axle....did what you said and its working a treat...many thanks! - Paul |
