Home > Technical (L322) > How to find an Airleak on the TD6 fuel lines :( |
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 |
The problem I had was the high Pressure pipe between the high pressure pump on the front of the engine and the fuel rail. It would cause the fuel to rain back to the tank when Parked but would leak when running can you see or smell any fuel leaking.
9th Oct 2012 7:55pm |
No fuel leaking from what I can see as it just seems to happen under load as it sat and idled for ages earlier after I swapped the pump out FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
9th Oct 2012 7:59pm |
Well a quick bit of testing shows that the air is being pulled in by the pump.
10th Oct 2012 10:24am |
trainmanone Member Since: 26 Jul 2012 Location: stockport Posts: 201 |
what was the outcome?? have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
13th Apr 2014 3:00pm |
